Old 02-20-2014, 10:30 AM   #1
james schaechter
Default Re: Header Retention Rule Revision
Originally Posted by Randall Klein View Post
Look Brett, I admire your history and passion for the sport, however I find your veiled historical snarky comments a little tiring....and not the Boertman comment alone either
At Topeka got ran over by a kid on a mini scooter, at Denver, in the restricted area under the tower, got a rock off a burnout just above the eye, and on and on omver 25 years....stuff happens, and if you've been around for awhile there's plenty of danger at the strip
A nanny state tries to insulate all from any possible consequences....maybe those worried about any potential harm should take up curling...oh wait! There was an injury in curling...maybe just stay in bed
True enough.
I am glad NHRA finally opened their eyes to other acceptable solutions to reduce risk and improve safety. Hopefully, they will learn to take a more reasonable approach to this in the future. If you recall, NHRA was suppossed to be dedicated to safety. That does not mean that all risk is eliminated.
I am sure that top management did not want to perform the due diligence that would have landed them where they are now.
I have said it before. The upper management at NHRA should be facilitating the discussions with qualified experts that they could consult within NHRA, their membership, and others. When they stifle this kind of discussion, they are left with a very narrow range of solutions that carry unintended consequences.
It is a shame that NHRA has no regard for the investment in time and resources that some have put forth in making tethers, but that should not be a surprise.
I think the common sense revision is a good one, and I like it. I just hate the way they got there. It is the same process that affects much of their decision making. I love class racing, I really hope that some changes are made in key positions so that the direction of the association meets the needs of the racers and fans. Even though NHRA dominates now, it will ultimately be replaced in some fashion if they continue to miss the mark on every opportunity. Time for a gut check at the top. Maybe the brass will come out to talk at another National event like they did at Indy. Remember that one....
James Schaechter 3163 STK
Old 02-20-2014, 10:56 AM   #2
Chad Rhodes
what a disaster
Chad Rhodes 2113 I/SA
Old 02-20-2014, 11:35 AM   #3
fredjohnston
Liked 55 Times in 14 Posts
I'm not sure about anyone else, but I think I would rather have a nice looking tether or a small weld on my header/collectors than drilling the body/frame and using a tail pipe hanger.
Just my opinion.
fredjohnston is offline   Reply With Quote
Old 02-20-2014, 11:43 AM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Originally Posted by Chad Rhodes View Post
what a disaster
X100
I still do not understand why the tabs with nuts and bolts that hold the collector to the primary tubes is not enough. Jack Mullins used to hold his collectors on with a bent piece of coat hanger; his never fell off. I figure its a matter of statistical percentages: so .000017% of the number of passes have collector incidents under the old rules. Under the new rules, .000004% will have collector incidents. Wow, I feel so safe now! Totally out of control and reasonable dialog.
Old 02-20-2014, 11:49 AM   #5
Ed Wright
Ed Wright's Avatar
X100
I agree. If guys would just use steel self locking nuts (not fiber locks) and keep an eye on them and the welds on the tabs, there would be no problems. Just start to bar the guys that loose them from running any more events, they would pay more attention.
And, I bet Jack used a real good grade coat hanger. LOL
Ed Wright 4156 SS/JA
Old 02-20-2014, 02:38 PM   #6
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Or just use safety wire with drilled bolts? Seems like another easy solution.
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 02-20-2014, 02:56 PM   #7
Ed Wright
Ed Wright's Avatar
That too.
