Liked 4 Times in 1 Post
Needing to buy a new set of tires for our J stock camaro any suggestions on what brand, compound, rollout etc. ?
Liked 56 Times in 27 Posts
Marco,
To start off , I would buy what was on it when you got it ? ( 27/28") in the front & ( 92.5 ") 30 X 9" Radials slicks in the rear .. I would buy Hoosier's... Remember , front tires size will depend on how you like to leave on the tree/ light ( R/O) & starting line... Good Luck with you New ride !!!
Dave Ribeiro 1033 STK |
J Stock as in Stick or Automatic? Makes a difference.
James Schaechter 3163 STK |
Jim,
It's an Auto, he bought Big Jim Harrington J/SA Camaro from Anthony. You are I00 % right on stick vs auto ....
Liked 21 Times in 6 Posts
Call Larry Hodge Tire and Wheel 217-433-3060
Who is a Hoosier dealer down south I'm in Florida
Thanks for the help and yes it is an Automatic I think I'm going to give Hoosiers a try there are Mickeys on there now I was just curious if one may be a tad faster than the other
A lot of good choices for tires. I have heard good things about most brands. I use MTs for a stickshift application. Check the rollout to see how they fit in the rpm range you are shooting for also. Radials are regarded as being fasternthan bias ply for automatics, and there are some that are lighter than others. I think you need to research your combo a bit before deciding.
By the way, Larry Hodge has LOT OF EXPERIENCE with stock superstock and offers Hoosier and MT. He can ship anywhere.
Liked 10,941 Times in 2,259 Posts
Goodyear, 100+ runs on my car and over half of the check hole left. The rubber does not stick to the car as bad as the others. I'll bet you will like them!
Liked 138 Times in 51 Posts
Keith Osborne is the Hoosier dealer who comes to all the NHRA divisionals. He should be in SGMP but I was told that they are also considering attending the IHRA Nitro Jam/Divisional in Bradenton.
But contacting Hoosier South should provide a dealer closest to you. http://www.hoosiertire.com/dist/disthtsrd.htm
LOCOMOTION Racing |
