Old 02-22-2014, 09:19 AM   #14
fordteacherguy
Liked 160 Times in 51 Posts
Default Re: best cam for L/SA 89 Mustang
Whatever cam you try, be careful to check piston to valve clearance, especially intake as there is more or less room depending on what piston you use. If you have a quality stocker piston w/ valve reliefs in the right place and angle, no problem most choices. If you are using factory stock or low buck cast pistons, valve clearance is way less forgiving. Let your clay be your guide!
fordteacherguy is offline   Reply With Quote
