Old 03-06-2014, 08:45 AM   #1
Chad Rhodes
Default Re: EFI Fuel Pump
Originally Posted by SSGN View Post
We use the Walbro or Racetronix pumps. These are an in tank that keeps the pump cool and support 9 second cars with ease. If need be you can run 2 pumps on one hanger .
http://racetronix.com/
Kevin
Well I'm pretty sure very few stockers/SS are running stock tanks.
Chad Rhodes 2113 I/SA
Old 03-06-2014, 09:01 AM   #2
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Thumbs up Re: EFI Fuel Pump
Chad with these pumps you can run a stock tank if wanted or they are also available with fuel cell mounts. I believe Aeromotive sells the fuel cell mount. Great pump at a great price. Use a boost a pump set up and these pumps will feed a strong running combination
Kevin
Old 03-06-2014, 01:03 PM   #3
Ed Wright
Ed Wright's Avatar
Walbro pumps have such a high failure rate, I will never use another one. My shop was very busy, we installed some of those since we could just call NAPA or O'Reily's and have one delivered quick. Had to eat too many. Borg Warner, etc , are about all reboxed Walbro. When the new pump weighs about half the orig pump, you can tell yourself "yep, plastic is lighter than brass." Went back to buying from the dealer's parts dept to keep customers happy. No voltage booster band-aids needed for a good pump.
Ed Wright 4156 SS/JA
Old 03-06-2014, 01:23 PM   #4
Chad Rhodes
Kevin
I've always been leery of the dual pump setups on forced induction applications..................what if one pump dies
Old 03-06-2014, 01:58 PM   #5
Ed Wright
Ed Wright's Avatar
I fully agree. One capable pump is much more reliable.
Old 03-06-2014, 04:28 PM   #6
SSGN
SSGN's Avatar
Ed you are 100 % correct and the pumps that they had problems with were all replaced under warranty(I know but not the labour)
Chad Rhodes 2113 A/SA, I/SA
Chad we use 2 pumps in a forced induction and the second pump turns on with a hobbs switch as boost rises.
Kevin
Old 03-06-2014, 05:20 PM   #7
boostedf22c
boostedf22c's Avatar
2 pumps are a bad idea. And are a bandaid, not a solution.
Carey Bales
316D DD/AT
www.racetactics.net
boostedf22c is offline   Reply With Quote
Old 03-06-2014, 06:35 PM   #8
Painter
Liked 162 Times in 45 Posts
Well if my new nhra rule was laying by my chair instead of hiding in cyberspace I could say for sure, but I am real sure stock and super stock are limited to ONE fuel pump.
Painter is offline   Reply With Quote
