Dennis,
Several reasons why the switch back: 1- The original split was to allow the EFI cars to compete against each other and level out the HP factors. 2- When NHRA created the EFI specific classes, the thinking was that eventually we would blend them back into regular stock after they leveled out against each other. 3- Design inequities will always be an element of Stock category racing. This is why Stock Eliminator is categorized by weight vs horsepower with the element of weight being adjustable based on actual performance. 4- There are a number of racers that I am sure would gladly debate the consistency factor with you. 5- NHRA has too many classes in Stock (75) and Super Stock (85) eliminator categories. Eliminating the EFI classes reduces the overal class count by 26 classes. 6- To include or not include EFI cars back into regular Stock has been an ongoing debate among racers since the inception of the classes. When you look at ALL the elements, such as those listed above and what is best for the long term growth of this category putting EFI cars back into regular Stock made the most sense to NHRA and arguably many racers.
Len Imbrogno Last edited by Len Imbrogno; 09-27-2007 at 10:15 AM. |
Liked 5 Times in 3 Posts
Thanks, Len Here is a good example 1969 Camaro 325hp 396 VS 1997 Camaro 350 LTI
Both fit in E/SA 1969 3420lbs 1997 3530lbs Both have a 3 speed 1969 396 cubic inches 1997 350 cubic inches 1969 700+ cfm Q Jet 1997 600 cfm throttle body You tell me what looks better! |
FI works better
Chuck Beach 3340 STK |
Liked 55 Times in 14 Posts
Tommy you forgot the:
Aerodynamics Torque arm Suspension (on F-bodies) Weight distribution Rollererized engine components Evolution of technology will benefit the FI cars more than a car that's been beat on for 40 years... One is a steel head and steel manifold big block..one is an aluminum head aluminum manifold small block. Oh wait..they are advantages for the FI car and you seemed to have left them out Last edited by fredjohnston; 09-27-2007 at 01:01 PM. |
FI works better? Better than what? Is that why every N.A. comp car that has tried it has switched back to carbs? Or why Pro Stock has not switched? The carb will cool the fuel making more power. The FI fires the fuel in right at the port not on top of the manifold letting it cool. I will say after you have spent hours testing on a dyno and on the track the FI car is simpler to make a change with the laptop than disassemble the carb. But You have to have done the testing to know what change to make. And yes I have raced both and won with both.
Fred I will agree on the aero and the roller engine is a better deal. But is it better then 46" and 100 cfm?
PS I dont think Private Ryan's A/FIA Could hang with Fred Henson's A/SA 9.80's Pretty stout! All of the records are with in .030 A/FIA A/SA B/FIA C/SA and C/FIA E/FIA The only one that is faster is Private Ryan the old school cars are faster in C and E. So really are they better? |
Hey Let me help you all out! Go to the classified section and buy my car! I will show you all the tricks that all of us FI guys have like the control, alt, F7 tune up. It helped Mark Maul with the US Nationals in 06! Jim Waldo has switched and never looked back!
#8 | |
#9 | |
Guest
Posts: n/a
Why don't you bring up the Cam Specs??? That 390 int 401 lift cam in that 396 I'm sure is at a disatvantage. The intake on the 396 is also suspect, compared to an intake that just has to worry about charging Air into a MPI lower intake. Maybe not all FI cars have an avantage, but many of them have.Just look at the SS qualifying for that Atco Points race.
Todd Hoven 1035 Stk Quote:
Liked 783 Times in 195 Posts
Todd - FI is not legal in Pro Stock. Comparing comp engines and the engineering intake tracts they can construct to a stock eliminator engine limited to cylinder head technology that is 30 years old is ludicrous. 600 cfm throttle body is dry air, equivalent to 880 cfm carburetor for ability to pass enough air to mix with the fuel that can be programmed for volume and duration in accordance with valve action and forced into the cylinder at 40+ psi. No comparison. Not to mention that the LS1 heads flow better than the 396-325 heads and the intake tract is shorter.
Not even apples and oranges; more like rocks and monkeys. |
