Liked 275 Times in 76 Posts
Just curious what others are using. My hedmans that were the trick header when Evan Smith built the MMFF project stocker, have developed several cracks. I am looking at headman # 85617 that are a stepped header. The Kooks headers just seem to have too big of a primary tube from what I am seeing.
Thanks Sean
Liked 230 Times in 75 Posts
I have been using the Pacesetters they fit well in the chassis. I cut the collector off and used merge collector from performance welding.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
Liked 79 Times in 11 Posts
I use hedman also. love the fit and overall quality.
bob beals 7244 |
Liked 1,111 Times in 304 Posts
I have 1 5/8" FlowTech long tubes on my Mustang. I can`t say how they compare to anything else, since they are the only set I`ve tried to date. They are reasonably priced, clear the scattershield fine, and they won`t need collector tethers!
Liked 25 Times in 9 Posts
Sean,
1 1/2" Hooker Header with Ed`s collectors work on my Stocker. Don Anderson M/S #5342 ![]() |
Liked 4 Times in 3 Posts
out of the box you can't beat the flowtechs for fit and performance we stock and sell a lot of them
we replaced them on Beth's car with a set of the headman step headers and saw virtually no improvement untill we installed mark' lelchock's collectors on them so ANY 5.0 stocker we build from scratch gets them and i would build another one if IHRA would ever get there act together and straighten out how about a minus 2.00 second under pure stocker? Fast and consistent so even a cripple like me could drive it and go rounds after qualifying #1 ![]()
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
Thanks for all the responses. As others have found the results seem to be in the collectors. I have tried the original slip on collectors, the flowmaster scavenger merge collectors. All of these with and without an X-pipe. The flowmaster by far had the best results. I will be looking into the collectors that have been listed.
Thanks Sean
As far as the flow techs go is it worth the extra $100 or so to buy the ceramic coated version or is their coating not any good? No doubt Jet Hot would be better, but is it worth the extra $?
#9 | |
Liked 160 Times in 51 Posts
FYI, I also build my own merge collectors with the diy kits from Cone Engineering. Last edited by fordteacherguy; 03-09-2014 at 10:33 AM. |
Ditto on the cone engineering collectors worth the money. hedman #88390
