Old 03-12-2014, 10:07 AM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Default Re: Mustang 5.0 Stocker brake pressure
1.125 master cylinder.. general consensus seems to be pedal ratio so lemme at it!
'65 Mustang SS/L & L/SA
Old 03-12-2014, 01:47 PM   #2
Rory McNeil
Probably getting harder to find now, but when I was building my 85 Mustang, I found a stock 4 banger early Fox Mustang with manual brakes, and removed the factory brake pedal, aluminum master cylinder and mounting plate, along with the longer lines from the master cylinder to the distribution valve, and it has been working great for over 10 years now. I got my manual steering rack the same way.I just let the Ford engineers do the calculations.
NHRA 6390 STK
M/S 85 Mustang
Old 03-12-2014, 02:30 PM   #3
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
I used a mid 80s Ford Ranger master cylinder, 15/16" ,and a modified brake pedal from Baer ,with a pushrod that is slightly curved. what is nice about the ranger master cylinder, the lines are on the fender side, instead of being in the way.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 03-12-2014, 03:54 PM   #4
hookdaddy
Liked 8 Times in 3 Posts
Bobby, I think your dad has my caliper pressure gauge (plus my valve spring tester for that matter - lol ) - have you checked pressure?
Don Scholl
d.scholl@comcast.net
145Y Stock - 145H Super Comp
hookdaddy is offline   Reply With Quote
Old 03-12-2014, 05:56 PM   #5
Fr8teamster
Redrill your brake pedal so your pedal ratio is 5:1 put a .750 MC on it and you'll have right at 10000lbs. Brake line pressure
Fr8teamster is offline   Reply With Quote
Old 03-12-2014, 06:50 PM   #6
Charlie Laraia
My master cylinder support. Once I had the pedal ratio squared away, the firewall was not happy with the new found pedal pressure. Hey even the COPO's need a master cylinder brace.
Name:	Master cylinder2.JPG
Charlie Laraia is offline   Reply With Quote
