#1 | |
Liked 30 Times in 17 Posts
I have an email indicating the large core cam is ok as long as you aren't using roller cam bearings. I will try to find it and post it if I can. Tracy Last edited by Pedigo Perf; 03-12-2014 at 10:26 PM. |
#2 | |
Liked 99 Times in 49 Posts
Liked 9 Times in 8 Posts
So what's the verdict here? Roller cam bearings? 60mm tunnel? offset lifters? Lifter dia?
lot of grey area to sort thru |
Liked 444 Times in 145 Posts
60 mm tunnel, offset lifters, lifter diameter. What are you talking about? You went back 9 months for this? Do you race Stock or Super Stock?
Bruce Noland 1788 STK |
Liked 880 Times in 311 Posts
To quote Bobby " If it's not in the rule book it cannot be enforced. If that was the case they could make up any rule they wanted to and bounce someone just because they wanted to."
Dwight hit the nail on the head. But you guys have forgotten about "The other Rule Book" We may not be able to read it because "They Have It" It is called the " NHRA TECHNICAL POLICIES & PROCEDURES" manual. That is where the real rules that the Tech Dept follows are written. It pin points area like what is being discussed. Every Div Tech director should have one, somewhere & there should be one at every NHRA race. Between the "Rule Book" we get and their TECHNICAL POLICIES & PROCEDURES there should be no problem being consistent with rules. BTY: This is the same manual that the AHFS rules and procedures are listed in.
Adger Smith (Former SS) Last edited by Adger Smith; 12-24-2014 at 04:13 AM. Reason: SP& Add |
Only 8 days left, better hope for good WEATHER.
Liked 370 Times in 101 Posts
I can hardly wait.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
Liked 79 Times in 7 Posts
#10 | |
Who says you can't offset the bushing fore or aft? And place the lobe where it needs to be. This is a high end tool steel cam and lifters And for the guys that are going to jump all over me for moving the bushings to where they need to be......they been offset boring cylinder bores for years, what's the difference? |
