Old 03-16-2014, 02:39 PM   #11
Default Re: Dart Big "M" 396 Sportsman block...
Arnold, I've been getting mine from Dart through Liberty, but I do have a second source now. I spent a while with Rick from Dart yesterday talking specifically about the "396" block. I'll have to ask Jimmy more about his that we got last summer. Rick was telling me the latest version has non siamese bores, unlike the block they sell with 4.250" base bore. When I started talking to Dart about doing a 396 block, they were originally thinking they could just use the big bore casting, and having them start at 4.125", but I was told that did not work they way they had hoped, so they built a new set of patterns and boxes to do a 4.094" bore block. The 4.250" bore block is the same as the 4.600" bore block.
Old 03-16-2014, 05:01 PM   #12
carl hinkson
Liked 18 Times in 10 Posts
Originally Posted by Arnold Greene View Post
Maurice, I still have one of the blocks to assemble, so I am sure the paperwork is still at the shop. I will look for the machining paperwork Tuesday and get back to you.
Alan, both blocks that I have built, have siamese bores and the same casting # as the 427 Big M block. Also both blocks were around 4.11??? on the bore size. They were both purchased through Atech. I will try to call you later this week when I am at the shop, probably on Tuesday. The first block had blind head bolt holes, but the latest has two on each side that goes into water.
I am W/D for Dart if you have the serial number Dart should have all the specs on your block!!
carl hinkson is offline   Reply With Quote
Old 03-18-2014, 07:21 PM   #13
ken robinson
Liked 224 Times in 87 Posts
I 'm happy with the one I ran last year, nice piece . But the extra weight keeps the nose lower when it hits the tree . Be nice to lighten it up alittle . Can't rember if it a siamesed one or not ? Its at .060 now .
Old 03-18-2014, 07:29 PM   #14
There are a couple of places with a lightening program. One price I was given was $1,000.
Old 03-18-2014, 09:13 PM   #15
Bub Whitaker
The 2 Dart M 396 blocks we did in 2013 were not siamese. They were 287# as received, 270# after all machine work. Stock block 396 filled w/ hardblock 230#. Stock block 427/ 454 208# add 8 sleeves 224#. Dart is heavier, will take the .075 overbore for 396 - 402 / ring seal is better - no brainer...
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 03-18-2014, 09:30 PM   #16
Chad Rhodes
Actually Dart will do it now. And it's a bit more reasonable than $1000
Chad Rhodes 2113 I/SA
Old 03-18-2014, 09:35 PM   #17
Rick from Dart and I spoke about that, he was asking me about what was done to the last one I sold, and what it cost.
Old 03-18-2014, 10:03 PM   #18
Chad Rhodes
Rick's a good guy, talk to him all the time.
Old 03-22-2014, 01:14 PM   #19
ken robinson
Did they ( at Dart ) tell you ruffy how much weight they can remove with the lightening program , for the extra $$$. ? Ken R.
Old 03-22-2014, 04:05 PM   #20
Ken, you can probably get close to 50 pounds out, with a lot of work. You might get even more, but I'm not sure I would do it.
