Old 03-19-2014, 11:49 AM   #1
randy wilson
Liked 22 Times in 22 Posts
Default Re: piston to valve cl. check
Alan is right. There is a huge difference between actual spring pressure, and using checking springs. We've seen as much as .050. But that being said, if you get a min. one way, don't assume that min. applies when using actual spring pressure. In other words my min. is .035 intake, .080 exhaust with checker springs. I wouldn't use those numbers on actual spring pressure. At those settings I have seen the shadow of the exhaust valve in the piston. Other guys may have a very different take on this.
don,t have one
Old 03-19-2014, 01:52 PM   #2
Liked 1,880 Times in 422 Posts
If it is a rectangle port big block Chevy Stock Eliminator engine that makes enough power to be competitive, I'd be real surprised if you could not see the "shadow" of the valves on the piston.
Old 03-19-2014, 02:14 PM   #3
DIV3CR
Liked 3 Times in 1 Post
Check the valve lift at retainer with both
springs and see the difference
DIV3CR is offline   Reply With Quote
Old 03-19-2014, 07:30 PM   #4
richie 2
Liked 205 Times in 93 Posts
thank you.....exhaust im getting .105'' w/checking spring & dial indicator, .155'' w/race spring and clay method. The .028'' valve lash has been set while testing both ways...
Old 03-20-2014, 07:38 AM   #5
richie 2
thanks everyone....we are going with what we have measured w/the race spring installed. its well safe. The answer to the question therefore is "using the intended valve spring to measure p2v clearance gives appx. +.050'' more than what the checking spring method shows". sp.
