Old 03-19-2014, 01:52 PM   #1
Liked 1,893 Times in 423 Posts
Default Re: piston to valve cl. check
If it is a rectangle port big block Chevy Stock Eliminator engine that makes enough power to be competitive, I'd be real surprised if you could not see the "shadow" of the valves on the piston.
Old 03-19-2014, 02:14 PM   #2
DIV3CR
Liked 3 Times in 1 Post
Check the valve lift at retainer with both
springs and see the difference
DIV3CR is offline   Reply With Quote
Old 03-19-2014, 07:30 PM   #3
richie 2
Liked 205 Times in 93 Posts
thank you.....exhaust im getting .105'' w/checking spring & dial indicator, .155'' w/race spring and clay method. The .028'' valve lash has been set while testing both ways...
Old 03-20-2014, 07:38 AM   #4
richie 2
thanks everyone....we are going with what we have measured w/the race spring installed. its well safe. The answer to the question therefore is "using the intended valve spring to measure p2v clearance gives appx. +.050'' more than what the checking spring method shows". sp.
