Old 03-23-2014, 11:01 PM   #1
STR001
Default Re: Looking for rear shocks third gen camaro
Originally Posted by Chad Rhodes View Post
Same here
So rear coilovers are legal in IHRA stock eliminator class? Did you use the relocation mount for the lower shock mount or use the stud style rear shock? Thanks
STR001 is offline   Reply With Quote
Old 03-24-2014, 08:11 AM   #2
Chad Rhodes
They are not coil overs. They are stud mount. I guess they could be coil overs as they have a threaded body. The compression adjuster is on the bottom, extension is on top.
Chad Rhodes 2113 I/SA
Old 03-24-2014, 10:25 PM   #3
STR001
Thanks for the info. Greatly appreciate it.
