Old 03-24-2014, 02:24 PM   #1
SC1448
Liked 2 Times in 2 Posts
Thumbs up ProCharger P1SC-1 Reverse Rotation Supercharger
I have a polished-finish, fresh from ProCharger, P1SC-1 REVERSE ROTATION supercharger available for sale. This listing is for the supercharger ONLY except for 2 different size 6-rib driven pulleys and 1 idler pulley. NO brackets, plumbing, belts, hoses, etc. This unit has been in storage since receiving it back from ProCharger after a complete overhaul in 2008 (I have all the receipts). Prior to overhaul, it was removed from a C-5 Corvette and replaced with a larger unit. With the reverse rotation, the unit actually mounts "backwards" with the air intake facing forward and the driven pulley on the back facing the engine. This gets the unit away from hanging over top of hot exhaust headers, keeping it cooler and makes engine maintenance easier too. The unit's oil supply is fully self-contained which means there's no hassle with having to run oil pressure supply and return lines. Check out all the specifications for this unit on the ProCharger website: www.procharger.com/models.shtml
Some Basics: 9" wheel diameter, 1200 CFM, 32PSI Maximum Boost, 3" outlet diameter.
I see these units new going from about $2100.00 to $2400.00.
Pictures available.
Asking $1500.00 SHIPPED (lower 48)
PM on the forum or call / text: (215) 990-4628
Thanks for looking!
-Don
SC1448 is offline   Reply With Quote
Search this Thread:
Advanced Search
