Old 04-08-2014, 09:46 AM   #11
Bobby Lundholm
Liked 127 Times in 49 Posts
Default Re: disc brakes
Originally Posted by HandOverFist View Post
Bobby - When you fully retracted the pistons and first put the calipers/pads on the rotors did it require any effort? I've found some brake pads have just too much material/thickness when new to allow any clearance.
It took a little effort to get them in. I figured it would wear down once I got some time on them but it still continues to drag after 2 seasons now. Though I haven't been racing much over the last couple of years.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is online now   Reply With Quote
Old 04-08-2014, 09:51 AM   #12
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
One thing you might try is loosen the m/c from the firewall to see if the rod is fully retracting...with the fronts off the floor you can spin the wheels to see if there is any improvement. Using an aftermarket m/c and/or a lengthened brake rod? I recently had to remove the front pads on my partner's '66 Nova and take a DA sander with 80 grit to them to alleviate the same problem.
Rich Taylor
I/SA - 321
Old 04-08-2014, 01:32 PM   #13
Bobby Lundholm
It's for a 1969 Nova with a 396/350
Stock master cylinder.
Old 04-08-2014, 07:52 PM   #14
HandOverFist
Take them off and grind them down a little. Costs nothing to try and it worked for my buddy's Nova.
Rich Taylor
I/SA - 321
Old 04-14-2014, 11:41 PM   #15
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Small GM transmission spring in between the pads held in with the willwood cotter pin. No more drag
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 04-15-2014, 07:07 AM   #16
Greg Barsamian
Liked 427 Times in 97 Posts
For those not wanting to use a Mopar Master Cylinder, NAPA part number M2456 is a "Lightweight" Master cylinder that is a bolt in replacement for the heavier cast iron version.
http://www.napaonline.com/Catalog/Ca...456_0358745370
Old 04-15-2014, 09:57 AM   #17
HandOverFist
24mm or 15/16" bore...anyone here been using one and on what type of system (disc/disc - drum/disc) ?
Rich Taylor
I/SA - 321
