Old 04-18-2014, 09:14 AM   #1
65wagon
Default Re: 65 Plymouth wagon
I looked up Bill Koski 's car it's a 66 273 2 barrel with a 4 speed so I Think I can run a 4 speed because I think it was an option in my year not sure who I would check wit to be sure!
65wagon is offline   Reply With Quote
Old 04-18-2014, 09:22 AM   #2
ss wannabee
Liked 7 Times in 7 Posts
Didn't some of those 273's come with a Stromberg 2bbl?
ss wannabee is offline   Reply With Quote
Old 04-18-2014, 09:22 AM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Here you go... http://www.oldride.com/library/1965_...belvedere.html
Rich Taylor
I/SA - 321
Old 04-18-2014, 09:30 AM   #4
65wagon
Yes i believe they did have a stromburg and on that link it says the 4 speed was an option on all belvedere and satellite models.
Old 04-18-2014, 11:27 AM   #5
James L Miller
Liked 25 Times in 16 Posts
A friend of mine used to run a 1965 Plymouth Valiant with the 273. I remember him telling me the 1965 273 had a bigger carb. From the specs from NHRA, it looks like the Stromberg has a slightly larger venturi than the Carter BBD.
180 273 DP 8.8 1-2 B&B BBD-3843S/SM 3844S/AUTO 2463252 1.5 M 57.3 B,5
Carter Carb sizes – 1437/1063
Strom Carb sizes – 1437/1125
It also looks like the 318s got a bigger carb. I never knew they were different.
Mopar 2 Ya!
Old 04-18-2014, 11:51 AM   #6
65wagon
Awesome thank everybody for the info i am really excited about building this car i have a lot of the parts already just need to figure out what manual trans i can run for sure then i can get started building
Old 04-21-2014, 06:35 PM   #7
magnumv8
The 4 speed is no problem it is legal....160 hp rated stock heads,
167 hp rated with Edelbrock 60767 replacement heads....with the 2 bbl carb, small bore and valves hard to say if the 60767 heads would be worth the cost.....also the Stromberg carb is a legal replacement
D L Rambo....STK 1300
magnumv8 is offline   Reply With Quote
Old 04-21-2014, 06:50 PM   #8
John Lang
Liked 6 Times in 2 Posts
With all of the Killer cars in U/SA, and there is a bunch, I would give some strong thought about going with a 361 w/2bbl,or a 383 w/4bbl AFB ! Or even a 426 Wedge w/4bbl AFB ! The parts are available anywhere, and cheap ! No 4sp in Wagons in 65 ! I think ! ..John
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
