Hey guy's...question for you blokes running Stockers with a 4sp Jerico in a 1st gen Camaro...I've got a 67 Camaro and I'm fitting a DR4-4 Jerico...I've purchased the factory 4 speed cross member from Classic Industries but with a factory rubber GM trans mount it sits the transmission way to high in the tunnel...what do you guy's use for a cross member and trans mount when running a Jerico or is a custom cross member the only option??
Thanks in advance, Ross. |
Liked 115 Times in 35 Posts
My 67 camaro with a Jerico trans. has a custom crossmember. Not sure how much different it is as far as height from a stock crossmember. Never had a stock one in the car.
Liked 427 Times in 97 Posts
Had to cut & re-weld the "saddle" or "mount" on the cross member in my Chevelle in order to lower the angle of the transmission to the rear end.
Liked 54 Times in 27 Posts
The Jerico DR4 was a bolt-in for my 66 A body, except that I trimmed down a couple ribs on the top cover for more clearance to the hump.
