Liked 796 Times in 211 Posts
On a Stock elim. car, are Aluminum Roller
Rockers Allowed if your motor came with a Hydrualic Roller Cam ??
"Pistol" Pete Dutko |
Liked 129 Times in 59 Posts
As long as the factory mounting style (stud or shaft) remains the same, the roller-rockers should be OK. I noticed that T&D is now offering a stud mounted roller specifically designed for Stock Eliminator combinations.
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 269 Times in 99 Posts
You can run any stud mounted roller rocker.
Check geometry and lift at the valve as it may change.
