I don't use anything on mine. They move 2 or 3 inches the first weekend, never move after that. I don't use soap to mount them. I use as low as 13 psi in my radials. Faster cars may have different results. I'm usually 1.26 to 1.28 in 60'. Faster cars may slip them.
Ed Wright 4156 SS/JA |
Liked 4 Times in 1 Post
Are rim screws not suggested with Hoisers, by wheel manufactor or just in general by other racers?
Liked 333 Times in 180 Posts
DEFINATELY no rim screws with radials---because of the way the tire sidewalls are constructed if the tire moves and the screw breaks it will cut the bead up a recipe for disaster--- use bead locks or nothing at all-- a little slippage is normal on a radial--entirely different construction than a bias tire --ask the manufacturers or spend some time online see what is recommended
Liked 759 Times in 379 Posts
Just clean the tire and wheel's bead with acetone and mount them DRY!
Been running radial slicks since 2000 this way, 60 foot 1 teens now and the tires won't move on the rim after the first few hits |
Liked 2 Times in 1 Post
Thanks everyone! I knew I would get the "right" info & suggestions here.
RT - SS/X circa 1972. ![]() Talbot Racing Family |
Yes, lots of good information. I never heard that about radial slicks, I'm glad I asked too. FED 387, thank you for explaining.
