Old 10-03-2007, 10:10 PM   #1
Chad Rhodes
Default Holley Carb Question
is it possible to helicoil the threads in the squirter hole, and what size are said threads?
Chad Rhodes 2113 I/SA
Old 10-03-2007, 10:55 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Holley Carb Question
The thread size is a 12-28 NF ----not sure if a helicoil is made in that size OR if you do drill it out if there will be enough material left to screw in the helicoil---Comp 387
Old 10-04-2007, 06:38 AM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Holley Carb Question
It was a long time ago and I forgot what thread insert I actually used. It wasn't the correct one, but it was close. The screw was forced on and I had to use the hollow version because the insert basically blocked the original passages along the sides of the threads. Don't know if that's legal for class. But it got me by on my bracket car.
LOCOMOTION Racing
Old 10-04-2007, 08:39 AM   #4
Mike Hedger
Heli coil does sell a kit this size. You can try the high flow squirter screw first they have a few more threads.
Mike Hedger S/C 4646
MPH Racing and Fabrication
Mike Hedger is offline   Reply With Quote
Old 10-04-2007, 09:43 PM   #5
FED 387
AHeli coil does sell a 12-24NC but no 12-28NF---you might try a 12-24 and then run a 12-28 tap thru it see if it works---not sure if there are passages in the side of where the bolt goes thru--you might try the tech dept at Holley or any reputable carb guy to get an answer--Comp 387
Old 10-04-2007, 09:50 PM   #6
FED 387
Try calling
Lavizzi Precision Products
999 Regency Dr
Glendale Hts., Il 60139
1-800-323-1772
They sell a 12-28 helicoil kit----Comp 387
Old 10-05-2007, 12:00 AM   #7
RJ Sledge
Liked 288 Times in 90 Posts
Chad
I stripped the threads on the squirter, found a kit from Bo Laws web site and it worked great.
R J Sledge
RJ Sledge is online now   Reply With Quote
Old 10-05-2007, 05:46 PM   #8
Chad Rhodes
Originally Posted by r sledge View Post
Chad
R J Sledge
wow there's a name from the past. Didn't know he was still around. I will check that out.
Old 10-05-2007, 06:32 PM   #9
don R
I think they are now BLP
don R is offline   Reply With Quote
