Old 10-04-2007, 09:43 PM   #5
FED 387
Liked 333 Times in 180 Posts
Default Re: Holley Carb Question
AHeli coil does sell a 12-24NC but no 12-28NF---you might try a 12-24 and then run a 12-28 tap thru it see if it works---not sure if there are passages in the side of where the bolt goes thru--you might try the tech dept at Holley or any reputable carb guy to get an answer--Comp 387
