Old 10-07-2007, 02:52 PM   #1
Liked 1,830 Times in 415 Posts
Default Re: Undercover ported stock heads?
Allowing ported heads will only increase the cost, both of the heads and of the short blocks that go under the ported heads, since porting the heads will only increase the RPM the engines operate at.
What illegal part will you want to make legal next? And after that? And where will you draw the line?
Old 10-07-2007, 04:36 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
I am old enough to remember back when a Tech official could & would toss you if he just didn't think it looked right. They had leadership that wasn't concerned with lawsuits & threats from engine builders or racers. At that time NHRA tech was run with an iron hand and from my vanatage point, for the good of the sport. Maybe they need to take a good look at the way Nascar does things. Nascar has Invested in people & technology to strengthen their form of racing. I think It is way past time to quit counting beans & invest a few of them in more than the bank. Remember, a tree grows strong with a good root system. At this point I don't see much conceren for the root system in drag racing, only picking the fruit.
Adger Smith (Former SS)
Old 10-08-2007, 01:36 AM   #3
JP
JP's Avatar
That's well spoken!
JP is offline   Reply With Quote
Old 10-08-2007, 08:38 AM   #4
Greg Hill
Liked 279 Times in 68 Posts
If they would just pour the runners in stock and use the super stock volumes a lot of the problem would disappear.
Old 10-08-2007, 10:56 AM   #5
bsa633
Banned
Originally Posted by Ed OBrien View Post
For those of us that don't know the " common standard " What is it ? Have a nice day
I was under the impression that you really knew all about this ...
bsa633 is offline   Reply With Quote
Old 10-08-2007, 12:36 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,934 Times in 581 Posts
There is no doubt that allowing ported heads in stock will increase the cost to build the heads and engine.In super stock a good set of heads and intake cost around 8 to 10 grand. The issue with the CC size of the ports. If you use the SS volumes they are quite a bit larger than an actual stock port. The heads that I run have a intake runner volumn of 165 cc. The largest stock head that I have poured personally is about 157 CC. So you can see that if you use the SS head volumns the heads will be much larger than a stock head. Ported heads would not be a good idea for stock in my opinion.The move should be toward a more stock head. Even a rookie tech man should be able to detect heads that have been acid etched and shot blasted.
Mike
Mike Pearson 2485 SS
Old 10-08-2007, 01:59 PM   #7
LouisJeffery
Talking Re: Undercover ported stock heads?
Enforcing the current rules is alot easier than people think. 98% of the bogus heads can be found using just the qualifying sheet. Any stocker that runs more than one second under has had some bogused up stuff done to the heads. Surely there will be racers attacking my comment but you can only lie to yourselves!!!!!! Louis Jeffery 3225 stock
LouisJeffery is offline   Reply With Quote
Old 10-08-2007, 04:13 PM   #8
Rob Lloyd
There's nothing bogus in my cylinder head...
Rob Lloyd 3728 BF/S
Rob Lloyd is offline   Reply With Quote
Old 10-08-2007, 09:01 PM   #9
bsa633
Banned
Do I think there is bogus heads out there yes ! Do I know where the line is drawn no.if there is a standard what
is it ? That is the problem there is no rule . Have a nice day
If you get your heads from an enginebuilder that have alot of engines out there they seem to have a good feeling were that line is since very few get tossed for heads!
Old 10-08-2007, 11:40 PM   #10
Doug Patrick
NHRA already is pouring the runners in stock. They did everyone at Indy and have done it before also.
Doug Patrick is offline   Reply With Quote
