A 262 is basically a 305 with a smaller bore and stroke. If you're set on building a Monza, I would call it a 77 or 78 and put a 305 in it. I think that the extra cubes and stroke would more than offset the 9 HP difference. A Monza isn't an easy or cheap car to do correctly.
The 267 can be used in a 79-83 Malibu or Monte Carlo or 79-81 Camaro. Change some trim and facias on the Camaro and you can run a bunch of different 350s and 305s in it besides the 267(do you see where I'm going here?). To answer the original question, IMHO, the carb on the 262 is easier to deal with than the Dual-jet on the 267. I think that the 81-83 267@ 150 HP(79-80 are higher) is softer than the 76 262@ 171 HP. I would do an 81 Camaro with a 267 and find someone smarter than me to deal with the Dual-jet.
Liked 28 Times in 15 Posts
The two cars that we have available are a 83' Camaro already setup for a 305 with a 12 bolt and 5.13s, metric 200 trans, etc or a 75 Camaro that is being raced with either my old 305 or a 350. The 83 ran I or J last and was just a 3 to 4 tenths under car. So one car would run in Gt with a 262 or 267 and the other would need a nose change at least and run a 267. Well it's raining for the third day here guess it's time to go get muddy in the junkyard!
#3 | |
That would work well and we actually ran it something like that up north but that's another story. Found a v8 Monza hatch back in the yard, missing carb and radiator. That's two v8 Monza's in two yards 10 miles apart.
If they're solid cars, go for it. Monzas are cool!
#6 | |
Liked 49 Times in 15 Posts
It gets even more interesting if you convert apples to apples. Since a 2BL is flowed at 3 inches vacuum and a 4BL is flowed at 1.5 inches of vacuum, you need to multiply the 2BL CFM by roughly .707 to get a value you can directly compare to a 4BL carb. So 287 X .707 = 203 CFM Using a quick online CFM calculator: 267 CID, 5500 RPM, 80% VE........ would need about 350 CFM minimum
Dean Feiock -- Stock 5002 |
#7 | |
I can assure you that a 287 CFM 2V will be flowing at least 100% VE. How can I say that? If everything is right in the combo, the engine WILL be pulling vacuum long before it gets to the finish line. OBTW, try explaining that to the man designing your cam.
#8 | |
Since the wife want's to drive and I've acquired another car......I guess I'll take a stab at it.
#9 | |
Liked 308 Times in 103 Posts
carb is rated 287,on dyno with air turbine will pull more than 287 cfm. Mike Taylor 3601 |
Hey Mike, not for nuthin but a 267 and a 4 speed in your car would be a crapper full of fun!
