Old 05-27-2014, 06:13 PM   #1
Rich67stang
Liked 116 Times in 27 Posts
Default Re: All racers please read this reminder!
Originally Posted by Rusty2211 View Post
This should cut down on the tribal, transbrake test mating call that echos through the pits of most events.
This is the way most .90 guys (myself included) set/test throttle stop rpm before actually making a run. If we have to put it up on jack stands to do it, so be it, not a big deal.
Richard Preiser
1613 FGT/I 1510 C/SA 161 F/DA
Rich67stang is offline   Reply With Quote
Old 05-27-2014, 06:47 PM   #2
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
thanks Debbie , we all can use a reminder where safety is concerned!!
jim powers is offline   Reply With Quote
Old 05-27-2014, 06:49 PM   #3
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
doesn't make a lot of sense for guys like me with a manual trans...
never seen one just "drop" into gear...
Old 05-27-2014, 08:02 PM   #4
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Didn't somene get killed out west several years ago, testing a trans brake, and crashed into a trailer.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 05-27-2014, 10:10 PM   #5
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
OK I am too old - but I never needed NHRA to pass a rule for me to use jack stands even when it is inconvenient and so much work and very time consuming - OMG
"COME ON MAN"
You need a rule for that ...
Ron
Old 05-28-2014, 01:52 AM   #6
Run to Rund
Liked 56 Times in 29 Posts
NHRA has apparently also decreed that electrons flow from the cathode to the anode, and therefore the shutoff switch is on the + side. The laws of physics and common sense do not apply at NHRA races.
Old 05-28-2014, 10:49 AM   #7
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Actually, this makes sense in a race car. If the cut-off were on the ground side and metal contacted that terminal or wire in a wreck, the circuit would be complete and current would flow to all the engine electronics and fuel pump. Cut the positive and current to the systems is stopped.
Dale
Dale Shearon
68 Mustang 6394
Old 05-28-2014, 02:21 PM   #8
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Accident at Fontana
http://www.competitionplus.com/drag-...nt-claims-life
You hear it all the time in the pits with people and there trans brakes.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 05-28-2014, 06:04 PM   #9
Bill Harris
Liked 26 Times in 13 Posts
Rusty2211 is right. Listen any morning in the pits and it sounds like Jurassic park.
Why is there a need to "test" the throttle stop RPM? Every NHRA accepted delay box is digital and the desired RPM is set to a particular value. Have you ever "tested" it and found it to not be the RPM that you set? It sounds like something that is done habitually and has no real useful purpose, sort of like motorcycle riders who cannot let their bikes simply idle at a stop light and have to continually wing the engine. No purpose, just a habit and an annoyance, but a dangerous one in this case.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 05-28-2014, 06:18 PM   #10
Alan Kenny
"Every NHRA accepted delay box is digital and the desired RPM is set to a particular value" Absolutely, completely wrong! Just the opposite is true. You CANNOT set or control throttle stop RPM with a legal delay box!!!!!!!!!!!
Alan Kenny is offline   Reply With Quote
