Old 06-14-2014, 08:38 PM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 553 Times in 216 Posts
Default Re: LT1 Camaro Timing Issues
Line up your crank trigger wheel and timing pointer on number one cylinder.......pull the cap off and see where the rotor is pointing to in the cap.....if something happened to the distributer or cam you should see it there...Rotor should be pointing somewhere close to number one terminal in the cap. I would bet it is not....and something failed like Lee pointed to.....
Do you send the crank trigger signal into your ECU and then to your ignition box......or bypass the ECU and direct to the ignition box with locked timing....?
I ran my LT-1 with locked timing and did not use the ECU to change the timing.....
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 06-16-2014, 10:43 PM   #2
camaro95
Thanks everyone for the info. Found rotor hub had slipped causing #2 cylinder to fire when #1 was suppose to. Not sure what caused it to slip, no damage to the rotor or cap was seen. Runs good now, hopefully no damage from the backfiring at high rpm
camaro95 is offline   Reply With Quote
Old 06-17-2014, 08:43 AM   #3
Ed Wright
Ed Wright's Avatar
Cheaper and easier than having keyways cut, you can do like many have done to LT1s with blowers. Drill in from the front, between the crank & hub for a 1/4" roll pin. Drive that thing in there, it will be half in the crank snout & half in the hub.
If this is a Stocker or Super Stocker you should be running a SFI dampener anyway, which will already have a keyway. The crank should already have one. Put the key in and nothing will slip. I would recommend an ATI dampener.
Ed Wright 4156 SS/JA
Old 06-17-2014, 07:49 PM   #4
joelster
Glad you found the problem!
Side note for you guys especially PETE- how many times have you seen LT1 cars break the dowel pin off?
joelster is offline   Reply With Quote
Old 06-17-2014, 07:56 PM   #5
Rich Biebel
None....
Never broke a thing in there...and don't think the present car owner ever had a failure there either......he has 2 LT-1 stockers
Gutted stock distributer....MSD cap and rotor....crank trigger...
Rich Biebel
S/C 1479
Stock 147R
Old 06-17-2014, 08:10 PM   #6
Ed Wright
Ed Wright's Avatar
I have only seen a couple.
Old 06-17-2014, 10:25 PM   #7
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
I've had 3-4 cam pins break on our cars from 98-2010. I broke one at a bracket race, and I pulled it down found the problem, but I couldn't fix it at the track. I put it back together and runnered up the race like that.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
