Old 06-21-2014, 11:24 AM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Re: DA shock adjustment
Originally Posted by Grant Eldridge View Post
Ron, my 70 Nova BBC had Moroso front springs, 90/10 Lakewood front shocks, Koni dual adjustable rear shocks, 9" tire stocker. With mine, we set the extension very stiff at about 1-2 clicks from the stiffest setting and the compression at the mid point of adjustment. Car would launch at 3400 with 60' best of 1.41. My thought was to slow the extension of the shock as much as possible so the car could get out farther before the suspension reached full extension. We felt that if it reached full travel too quickly it could unhook the tires at that point, sounds like that could possibly be happening in your case,
just my 2 cents.....
Grant Eldridge
E/SA 6650
Thanks Grant, I'll give that a try. I may have misunderstood Moneymaker when he said "Go as stiff as you can until it spins and then back off", he may have been talking about the initial hit. I'm trying to make it work until I can scrape together enough money for new tires. I'm running on a track that gets prepped once at the beginning of the day and goes downhill from there.
Ron Gusack is offline   Reply With Quote
Old 06-23-2014, 10:11 AM   #2
Ron Gusack
Ron Gusack's Avatar
Grant, thanks for your help on extension settings. I didn't go 2 clicks from the stiffest, but I went about midway and the car worked much better. I would have done exactly what you said, but I didn't remember 1 or 2 from stiffest. I haven't been able to find info on exactly how to set them. I'm sure it's out there though. You S and SS guys are really sharp and it helps us little guys a ton when you share info.
Thanks
Ron
