Old 10-10-2007, 10:00 PM   #1
racerdale
Default Re: Newbie Building a Ford Maverick
Originally Posted by greg fulk View Post
Hey Dale ya don't loose "as much" money with a stocker when ya sell it as ya would with a bracket car....stock is one of those things that once ya do it your pretty much hooked! no buy backs, no playing games in the staging lanes & a real good group to race with! at least here in Div.3......good luck & if ya have any other question feel free to ask.
Hi Greg, Thanks for your offer. I am just now getting started with the project and I already have the heads , manifold and carb. The block will go out in a week or so to the machine shop. There is not much you can do to the block and I would imagine that I should have the deck height set at a few thou over spec. I am not familiar with OEM Crankshafts and not sure who would be a good supplier. Got any ideas? They list a few manufactures in the tech replacement guide for rods and pistons so I will cross that bridge when It get that far. Thanks again
Dale
racerdale is offline   Reply With Quote
Old 10-10-2007, 11:05 PM   #2
Geerhead55
Liked 5 Times in 5 Posts
Talking Re: Newbie Building a Ford Maverick
Dale!!!! Wow this is a surprise! I did'nt know you were going to give Stock Eliminator a try. You should 've come up in the tower and told me. Best of luck with your project. I will deffinately see you at the Bremerton banquet next month,, I have a couple awards to hand out to some deserving racers.
Rory,,,,,, thanks for the info on the former Waldo car. I wonder if Brian will run it as a C car, or try another combo in it. I guess time will tell.
See ya guys later,,,,,,,, Danny Durham
Old 10-11-2007, 02:24 AM   #3
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Dale I set the deck dead on. you can play with head gasket to get that right. as for cranks don't forget it's + or - .015 most everyone goes + .012 now for pistons make sure you use a floating pin piston...little motor with low Hp needs to get rid of all the friction it can....I know ran a 230 6cyl for years (dad still dose) & set 5 IHRA records with it. I now have a P/SA 307 cutlass that can run 12.60's on these low Hp engines frictions kills! oh & don't forget dry film coated bearings.....friction.
Old 10-19-2007, 07:30 PM   #4
racerdale
Hey Greg,
Thanks for the tips I will put that information to good use.
Thanks
Dale
Old 10-19-2007, 07:28 PM   #5
racerdale
Danny,
I have wanted to build a stock eliminator for years but as you know my wife was seriously ill for the past few years. That put my racing on hold. I only had the Pinto out 4 or 5 times this year and it broke every time. Never got it fixed to make a full race except for last race and it got rained out. I picked up this old Maverick a while back and was going to turn it into a street hot rod but after I saw Brians Comet I said that could work for me. So here I go. I may have it ready for track testing by May. See you at the banquet.
Dale
