Old 06-26-2014, 11:51 AM   #11
Ed Wright
Ed Wright's Avatar
Default Re: Trailer tires - 15 vs. 16
Jeff's advice cured my trailer tire problem years ago. Listen to him. I didn't know trailer tires are speed rated to 65 MPH. I used to never drive that slow. Fuel has gotten so expensive, and since I have pretty much retired, I tow a little slower now. LOL
I had 6 lug 15's, I bought 16" wheels at a local trailer supply, and 10 ply Michlien tires. No more tire problems. Tows so much better. Trailer doesn't bobble when meeting big trucks on 2 lane roads now.
Had to tear a fender off my trailer in the middle of the night next to south Dallas to learn the hard way.
Ed Wright 4156 SS/JA
Old 06-28-2014, 02:28 PM   #12
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
I was having problems with 10 ply 15 in. tires blowing out on my trailer, 5,200 lb. axles with 6 lugs. Switched to 16 in. and haven't had a problem since. It's worth the peace of mind also. Again, listen to Jeff, he knows what he's talking about!
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 06-29-2014, 12:19 PM   #13
Run to Rund
Liked 56 Times in 29 Posts
First, never underinflate trailer tires in an attempt to "match" their weight capacity to a load on them that is less than their max rating. E-rated tires take up to 80 psi and don't run less than about 75 even if the trailer is light. Second, it is best if they are loaded not over about 80% of max, especially if you want to run about 72 mph across the big western states where 75 mph is the speed limit. Third, if there is any chance the trailer weight is near the max for the tires, weigh each wheel's load to be sure the weight is evenly distributed and no tire is overloaded.
When we get info about problems with 15" that were "solved" with 16" truck tires, sometimes it is caused by bad 15" trailer tires, especially Chinese made tires. Sometimes it is caused by high highway speeds on overloaded tires, and the 16" tire had a higher weight capacity and is more forgiving of 75-80 mph in hot weather. It is very easy to load a lot of stuff into the trailer that doesn't seem so heavy on an item-by-item basis, but in aggregate was too much.
Old 06-29-2014, 07:34 PM   #14
Greg Hill
Liked 279 Times in 68 Posts
The only tires I've had good experiences with are the 16" commercial tires like the Goodyear 614, the Bridgestone R250, or the Michelin XPS Rib. What all these tires have in common is that they have steel in the sidewalls. Be careful using any LT truck tires on your trailer.
Greg Hill 4171 STK
Old 04-29-2016, 08:08 AM   #15
gbur
Originally Posted by drace69 View Post
Anybody had any experience with the Hercules 15" - 'E' rated trailer tires?
Know that this thread is old but has anyone used Hercules E tires, ?
Gary Burr IHRA MEMBER # 1958 Stk 1949
gbur is offline   Reply With Quote
Old 05-01-2016, 07:06 PM   #16
Run to Rund
Check the sidewall carefully; place of mfg is usually near the bead. I think they may be made in China. If so I would avoid them.
Old 05-04-2016, 04:57 PM   #17
Rusty Davenport
Liked 101 Times in 27 Posts
I have been seeing a lot of Firestone Transforce on race trailers ( 16E ) ......anybody got any trailer use info on these or had time to test them ?????
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 05-04-2016, 10:46 PM   #18
Sean Marconette
Sean Marconette's Avatar
Liked 276 Times in 77 Posts
Rusty,
I have them on both my dually and my 48' LQ trailer. I have never had an issue. This is the second set on the dually. They have only been on the trailer for one season.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 05-18-2016, 10:49 PM   #19
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
I did this 7/8 yrs ago. Makes a huge difference towing. I got my steel wheels, gray ones, for something like $30 ea. from Southwest Wheel. I think it's part of SWTrailer or something like that. I found some 10 ply 215/16's that were the best fit on my 28 ft trailer, and a good weight rating. Look for a LT truck tire. IMO! They will last the longest. Had 1 go since then. I've towed from Ga to Fla, to Va, to La and Tx. A lot of these guys have a lot more miles than me, but, to me it was a no lose deal.
Unfortunately, unless you do a lot of digging to find some of the few tires still made here, you gonna find Chinese everywhere. Good luck !
2894 STK
