We put ours on the top. Easy to use and we can chill to 55 degrees if we want to
James Schaechter 3163 STK |
Liked 333 Times in 180 Posts
what ever is most convienent access!!! if you have a circulating pump it really makes no difference as the water is moving thru the cooling system anyway--FED387
Liked 1,471 Times in 308 Posts
Thanks guys.
Liked 3 Times in 2 Posts
On our Yates headed motor we go directly into the front of the heads since we have no upper water fill. I have seen some that had it hooked directly to the radiator as well, I would imagine it was a custom piece...
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
