Old 07-07-2014, 08:31 PM   #1
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Help-Powerglide-big leak when on the brake?
Seems strange that the case should fail at that seam line. What line pressure do you run in Rev, and when the Trans Brake is on? Maybe the pressure is too high and stresses the case.
Old 07-07-2014, 10:49 PM   #2
cad
cad's Avatar
Liked 93 Times in 52 Posts
Dye immediately showed when on the brake. dont know what pressure it is set at. Since the ultracase isnt available in time for a 3 race weekend, I ordered a 1 pc sfi glide case and have the trans pulled. Appt made with my trans guy for wed night if fedex shows up on time. He will swap everything over while I wait for $100. Ultrabell will be for sale...lol. dated dec 2013 I believe.
Old 07-08-2014, 07:29 AM   #3
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Check the driveshaft for run-out (before you pull the transmission back out) and get it balanced if you have time. I had an off center pinion yoke that was causing run-out and it killed 2 cases for me before I fixed the issue.
Pedigo Perf is offline   Reply With Quote
Old 07-08-2014, 08:04 AM   #4
SGSST109E
Liked 126 Times in 61 Posts
A bent drive shaft will do it.
SGSST109E is offline   Reply With Quote
