Old 07-08-2014, 08:44 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Re: Drum brake chatter
I'm more concerned with it holding on the starting line and I've been told drums were better than discs for that. I foot brake and sometimes the brakes won't hold the car at much above 3200. This chatter problem didn't start until I put long shoes in all eight spots. I'm wondering if the secondary shoe on the primary side is the problem.
Ron Gusack is offline   Reply With Quote
Old 07-09-2014, 05:24 PM   #2
bigfoot584
Ron, years ago we use to have to put 1/8" to 3/16" bevel on the leading and trailing edge of shoes to help with that sometimes, also I wouldn't run both long shoes on the rear but I would in front. We also would take a hack saw and put a diamond pattern across the face of the shoes spaced out about an inch then turn saw other direction come back the same distance, go about 1/4 to 1/3 into shoe surface be careful on riveted shoes for depth, this helps chase some of the heat out. Try taking 80 grit sand paper and scuff rear shoes and drums then clean well with brake clean before you go out again, it's possible you had oily finger prints on one or other.
Good Luck
bigfoot584 is offline   Reply With Quote
Old 07-09-2014, 08:16 PM   #3
Ron Gusack
Ron Gusack's Avatar
Thanks for the tips Bigfoot. I took a file and beveled the lead edge of the primary shoe, but it was a very slight bevel. I've only been 106 in the 1/8 mile since I changed shoes and it only does it if I hit the pedal pretty hard. I'm holding off 1/4 mile stuff till I get it figured out.
Old 07-09-2014, 09:41 PM   #4
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Good advice from Bigfoot, I used to do that back in my Firestone brake mechanic job. People would come in and say, my car pulls to the right, we would say, step on the left side of the brake pedal....
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
