Liked 10,891 Times in 2,255 Posts
156 runs and counting! Tom Losket checked the tread depth at 153 runs and it checked 4/32". Best 60' 1.29, in my A/SA @ 3410 lbs. 550+ Ft./lbs. torque.
It's the best tire I have ever had on my car, and it looks like it will be the cheapest. |
Liked 240 Times in 112 Posts
Wow, that's impressive. Can I ask about your burnout technique ?
Dave Noll, EF/S ,?/SA 6526 |
X2 on the burnout ...
I'll be looking for a new set after this next divisional, might give them a try. |
I try to keep wheel speed low, second gear only, so the tire remains as flat as possible and the tire does not crown. Start at 5700 and as the tires clean it will start to drag the engine down below 5600 let go of line lock and ease out of the water while slowly reducing power.
Liked 670 Times in 202 Posts
How often are you swapping side to side?
Eight to ten runs
Liked 314 Times in 113 Posts
Larry,
A couple more questions since you seem to be in answer mode. 1. How wide a wheel do you use? 2. Are they mounted tubeless? 3. Approximately what air pressure do you run? 4. Do the tires leak air between races? Thanks in advance.
Larry Merk |
Liked 2,361 Times in 558 Posts
I have them on both of my COPO Camaros and love them. These are my answers to your questions.
1. How wide a wheel do you use? 10" 2. Are they mounted tubeless? Yes 3. Approximately what air pressure do you run? 19 PSI 4. Do the tires leak air between races? No ![]() Last edited by GUMP; 07-10-2014 at 05:35 PM. |
Larry
1. 9'' or 10'' I have both, never know when a flat might happen. 2. yes 3. 20 lbs. 4. little if any. 5. Very little rubber sticks to the car, most of it brushes off quite easily. Last edited by Larry Hill; 07-11-2014 at 09:36 AM. |
I am thinking this may be my next tire choice.
What is the cross section width on a 10" rim? Thanks
Peter Ash 6100 STK |
