Old 07-10-2014, 06:59 AM   #1
Liked 10,916 Times in 2,256 Posts
Default Re: Goodyear 4457 Radial
Eight to ten runs
Old 07-10-2014, 05:17 PM   #2
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
Larry,
A couple more questions since you seem to be in answer mode.
1. How wide a wheel do you use?
2. Are they mounted tubeless?
3. Approximately what air pressure do you run?
4. Do the tires leak air between races?
Thanks in advance.
Larry Merk
Larry Merk is offline   Reply With Quote
Old 07-10-2014, 05:32 PM   #3
GUMP
Liked 2,361 Times in 558 Posts
I have them on both of my COPO Camaros and love them. These are my answers to your questions.
1. How wide a wheel do you use? 10"
2. Are they mounted tubeless? Yes
3. Approximately what air pressure do you run? 19 PSI
4. Do the tires leak air between races? No
Old 07-11-2014, 08:41 AM   #4
Larry
1. 9'' or 10'' I have both, never know when a flat might happen.
2. yes
3. 20 lbs.
4. little if any.
5. Very little rubber sticks to the car, most of it brushes off quite easily.
Old 07-11-2014, 01:32 PM   #5
Peter Ash
Peter Ash's Avatar
I am thinking this may be my next tire choice.
What is the cross section width on a 10" rim?
Thanks
Peter Ash 6100 STK
Peter Ash is offline   Reply With Quote
Old 07-11-2014, 02:32 PM   #6
I'll look.
Old 07-14-2014, 11:57 AM   #7
As best as I can tell the width of the tire on 10" wheels is aprox. 12 1/4"
