Liked 216 Times in 77 Posts
IF it got that big of a dose of water. It might also have gotten some in the optispark. They are famous for problems when the water pump starts going bad and weeps antifreeze. I imagine a large dose all at once would cause similar opti problems.
Liked 13 Times in 7 Posts
Rob, Interesting comment.
As I was looking at the area where the water could go, it became apparent that the one connector receptacle, located around 11:00o'clock facing the engine is wide open and not utilized as this set-up is configured. Looking down into the receptacle with a flashlight exposes the 3 terminal prongs. I'm certain that this area was the recipient of a good bath during this process. As indicated in the previous posts, I'll continue down the path Mike suggested and complete the leakdown test . Hopefully I get good results. If I chase the optispark unit, does it need to come apart to "DRY OUT" or will time cure the problem??? Thanks John |
#3 | |
Liked 184 Times in 113 Posts
Water got in mine it created a small almost undetectable carbon track. PMed it with a new Cap and Rotor worked fine. Had a few Opti's fail. Tried 3 Summit versions because of price. All three failed in 6 months. It was the Trigger. Twice my GM brand new units failed after 6 months. Discovered carbon tracking the other a cracked rotor with carbon tracking. Always keep a rebuilt Unit and a Rebuild Kit. Never know when the water pump will spring a leak. D |
This car has a crank trigger....I believe that is why there is no harness connected to the receptacle for the optic sensor module.
However, The opening where the harness would connect is a direct path to allow water into the dist.cap/rotor area. I looked in ther with a flashlight and thwere was definitely moisture on the sensor terminals. Put a Q-tip in there and definitely came out wet. If leak down does not show anything, tomorrow I remove cap/rotor. |
#5 | |
Liked 2,361 Times in 558 Posts
Got a spare cap and rotor. Will replace tomorrow.
^^^^^^^^^ There ya go.
Ed Wright 4156 SS/JA |
As they say in the NFL....After further review"....
The valve train all checked out OK The motor leaked between 5-7% with one outlier at 9.5% (cold) There was evidence of moisture in the Optispark connector receptacle. Tomorrow will replace cap/rotor AND plug the connector hole as suggested. Thanks for a lot of great help. John |
