Old 07-11-2014, 02:59 PM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: LT1 issue
Originally Posted by John Nechiporchik View Post
Got it off. What a pain in the *** to change a dist, cap!!!!
I guess the Engineers never considered the service aspect of their design.
IF you think its bad on a race car. You should try it sometime on a street car with all the emmissions and other crap bolted to the front of the engine. Its a real sweatheart of a deal then. LOL.
How did it look was there water in it?
Old 07-11-2014, 06:10 PM   #2
John Nechiporchik
Liked 13 Times in 7 Posts
Rob,A minor waterfall came out after the dist cap fasteners were loosened. The area where the rotor and cap appeared OK. The water was behind the white plastic shield. The metal shield was rusty.
Incidentally, The unit still contained the cam timing disc and module. Is this still necessary with the crank trigger or can I take them out?
Also, I could not find a socket to remove the bottom two (recessed) fasteners on the cap.I had to modify a small pair of channel locks to remove them. What size star or metric is that??
Also, filled the Connector receptacle with silicone as discussed earlier.
Thanks,
John
John Nechiporchik is offline   Reply With Quote
Old 07-13-2014, 09:54 AM   #3
John Nechiporchik
OK....The Optispark cap bolts are E4 Torx. Not a socket found in regular tool or auto parts stores. Apparently Snap On and Matco carry them.
However, on another forum A guy posted that the throttle body cover screws are the correct size torx. As I had a spare throttle body, I removed one of the screws, chucked it up in a vice grips and got a tool (however crude) that works.
Old 07-13-2014, 10:18 AM   #4
Rob Petrie E395
That is basically what MSD sends you with a new cap and rotor or complete Optispark. Its just a screw with a thick nut on it. As far as taking the stuff out of the inside (wheel and sensor). I have always left mine in with no problems. Glad you found the problem and are back on track.
Old 07-13-2014, 10:36 AM   #5
John Nechiporchik
Thanks Rob.
