Old 07-14-2014, 01:42 PM   #1
FED 387
Liked 336 Times in 183 Posts
Default Re: Two trailer questions.
Look Trailers in Bristol Indiana @ 877-475-5665 might be able to help you on the glass---they bought Pace in Dec 2012
also call Dexter axle @ 574-295-7888 several variables come into play here--- like brake shoe dimensions 12 x 2 or 12 1/4 x 2 1/4 inches as well as the date when the axle was manufactured due to upgrades and modifications plus whether you have the never lube design or the convential hub etc. etc. etc.
Hope this helps FED 387
Old 07-14-2014, 02:54 PM   #2
gbur
try etrailer.com
Gary Burr IHRA MEMBER # 1958 Stk 1949
gbur is offline   Reply With Quote
Old 07-14-2014, 04:29 PM   #3
Jack Zimmerman
Liked 11 Times in 6 Posts
I'd bet that Pace didn't make the light fixtures that you have so if you take one apart you may find the manufacturer's name and then you can contact them for a new glass cover.
Jack Zimmerman is offline   Reply With Quote
Old 07-14-2014, 04:53 PM   #4
voltdr
Liked 100 Times in 51 Posts
Most any glass company can order "tempered" glass for you. Probably cheaper to replace the fixture itself.
Dan
voltdr is offline   Reply With Quote
