Old 07-16-2014, 10:09 PM   #1
Liked 10,895 Times in 2,255 Posts
Default Re: Weld Drag Star stuck on studs
Try heating the studs with a propane torch. this should cause a difference in expansion rates between the wheel and the studs and help break the bond. WD-40 the studs after they cool, jack up car so wheel will turn, get a 2" X 6"X 2 1/2' long so the end of the board will stand on floor and be against the sidewall. Now start asking the tire and wheel to start moving off the studs by using a 4lbs. hammer against the 2x6. Hit the 2x6 and rotate 180* strike again, rotate 90* and keep after it. Its kind of bouncy but you won't bend a wheel. Heat the end of the studs don't get them red hot, they are hot enough when a drop of water will dance on the stud. Keep in mind that there is a oil seal for the axle. Good luck!
Old 07-16-2014, 11:28 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
I had that exact problem with my drag stars too. What I do is use a Stanley "Magic Bar" flat pry bar which fits perfectly through the spokes of the wheel, then pry between the wheel and hub, if you work it around in a star pattern, the wheel comes off no problem.
Old 07-17-2014, 12:33 AM   #3
older racer
Liked 68 Times in 26 Posts
hi,I have found that tightening aluminum wheels and other parts down tight, causes the aluminum edge of hole to roll inward and grasps the shaft of the bolt tightly. therefore , it is locked!!!! I toruqe my 5/8 wheel nuts to 65 #. I've had to run a round file through the wheel holes at times to take out the lip.just food for thought.
older racer is offline   Reply With Quote
Old 07-17-2014, 07:37 AM   #4
Kegracing
Thanks for all the suggestions everyone. Traveling with work this week, but looks like I know what my Saturday morning will be focused around! LOL
At least it is only projected to be about 90 Saturday. Cool front for TX this time of the year!
Will let you know how it goes.
Ken
Kegracing is offline   Reply With Quote
Old 07-19-2014, 10:45 PM   #5
Kegracing
Well,
Little hand torch, some WD 40, rubber mallet and dead blow, and all is good again.
I did take a file and clean up the holes on wheels when done.
I did get the two aspirin and a cold drink afterwards too... getting old sucks! LOL
Thanks everyone.
Old 07-20-2014, 07:58 AM   #6
Dragsinger
Liked 99 Times in 60 Posts
did you mix the aspirin with the wd40?
Larry Woodfin 471W
Old 07-20-2014, 10:08 AM   #7
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
I hope the "cold drink" was of the "adult" variety!
Bob Don 128 SS
