I have broken the 3-4 finger twice now this year,i believe the first one was original,the second one lasted 6 passes.I have had a DR4 for 5 seasons,always use the clutch,also has a LONG verticle shifter no stops.The first one was a clean break,looked like it was sheared off clean and straight,the second is fractured,very jagged! I talked to Jerico last Wednesday[July 16 2014],their responce was they had no idea of an issue as nobody has reported an issue?!!! I have read through all four pages and it looks like they will break with or without clutch use and with or without shifter stops.Has anyone come up with a reason or a solution? I just drove to a N/SS race 1500 miles away only to break Sunday morning,SUCKS!! ROY.
Liked 4,387 Times in 504 Posts
I am sorry to hear this Roy, I and many others share your frustration. I have had them break in the middle of money rounds where my opponent was broken and we both had to limp to the stripe (he won)!
But the good news is I finally found a machinist to make these for us out of 4150 chrome moly billet and I just got two of them yesterday to test for fit. They are mighty pretty pieces.. Will keep everyone updated. Last edited by Bobby Fazio; 07-22-2014 at 05:35 PM. |
Liked 54 Times in 27 Posts
Has anyone contacted Scott or others at Jerico, and what are they saying? I have not had any problem with my Jerico but now you have me worried! I use a Hurst/Mr. Gasket V-Gate2 with stops.
#4 | |
I'm obtaining new ones that are CNC machined from U.S made high strength billet SAE 4150 chromoly steel by a professional racing team. Last edited by Bobby Fazio; 07-23-2014 at 08:26 AM. |
One new finger in bag, the other we tried to break in the flat where the threads start since that is where they always seem to break. We used a big wrench with a pipe attached, tried adding heat also and that did not work either.. got it to bend a little bit.
Bobby;WOW,that should work!!!Any idea on their delivery date? ROY.
My only concern before ordering a bunch of these is the measurement of the flat area where the shift lever straddles the finger on the outside of the case. I have seen measurements of this area anywhere from .315-.326 on the five fingers I measured today. I would like to settle on a number with a little help from my fellow stick racers. I think I would rather have that be too big than too small and have play in the lever.
