Old 07-22-2014, 04:05 PM   #11
Ed Wright
Ed Wright's Avatar
Default Re: I want big wheelies
small wheelies are faster.
Ed Wright 4156 SS/JA
Old 07-22-2014, 04:43 PM   #12
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Ed is right, the higher u get the slower you will go. If the car keeps going up without moving forward you lose et.
Bob Pagano A/SA
Bob Pagano is online now   Reply With Quote
Old 07-22-2014, 05:03 PM   #13
Joe Schaechter
Joe Schaechter's Avatar
Liked 13 Times in 4 Posts
This wheelie didn't make our car quicker ET wise but it was fun! Also, the higher up you go there is also the issue of how to get the car to settle down and still make a good 1-2 shift with the four speed.
Joe Schaechter 3168 STK
Joe Schaechter is offline   Reply With Quote
Old 07-22-2014, 09:02 PM   #14
7423
ding ding ding...................we have a winner!!!
Go fast, stay consistent, still be in on Sunday and win races........or............do big wheelies
7423 is offline   Reply With Quote
Old 07-23-2014, 08:51 AM   #15
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I would say springs are problem,6 cyl worn out springs, when jack the car up I'm going to guess the springs almost or do become loose,if that is the case front end extends and you run out of spring,they don't have any stored energy,when you pull engine probaly does'nt raise front of car all the way up against the stops.
You want springs that have to be compressed quite a bit to end install,but soft enough to let car down to ride height you want,like the moroso's
Then if you wheelie to big you can adjust,one thing is can raise starting line rpm sometimes and wheelie less,by puttting controled spin on at the hit.
Mike Taylor 3601
Old 07-23-2014, 09:58 AM   #16
James Perrone
Liked 1,841 Times in 428 Posts
How much pinion angle do you have? More angle the better the wheelie.
james perrone 1290 STK
Old 07-23-2014, 03:30 PM   #17
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Originally Posted by Michael K View Post
Big wheelstands are only possible with gapless rings.
I knew it!!!
Thanks for all the input fellas...I realize small ones are faster, this thread wasn't meant to be real serious, just wanted to get some ideas and be sure I'm not leaving something obvious on the table.
I think areas for improvement are launch rpm, front springs, and clutch setup first. No data logger yet, just a playback tach and videos for clutch guessing.
Paul Merolla is offline   Reply With Quote
Old 07-23-2014, 06:45 PM   #18
Liked 1,880 Times in 422 Posts
So long as the small wheelstand transfers enough weight to hook up the maximum amount of power and clutch, and does it both consistently and reliably.
Old 07-23-2014, 07:27 PM   #19
Greg Hill
Liked 279 Times in 68 Posts
I think there is a big difference in a stick car and an automatic. An automatic likes to dead hook and if a stick car does that it usually pulls the motor down, although I've seen Jason McCormack do some huge wheelies. Our cars run faster when they leave with the wheels up in the air pretty good.
Greg Hill 4171 STK
