Old 07-25-2014, 08:44 PM   #1
Run to Rund
Liked 56 Times in 29 Posts
Default Re: Anyone have a shift finger for Jerico?
Best I could tell on my DR4 mfg. 2007 was .312" minimum, maybe up to ..315. Hard to squirm around and get a real good number, but I would say .312" is good.
Old 07-25-2014, 11:26 PM   #2
hookdaddy
Liked 8 Times in 3 Posts
Racers producing better parts is how most of today's suppliers got their start in business.
Don Scholl
d.scholl@comcast.net
145Y Stock - 145H Super Comp
hookdaddy is offline   Reply With Quote
Old 07-26-2014, 09:06 AM   #3
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,389 Times in 505 Posts
I am betting that the OEM finger was designed at .320 but due to the weaker material, it was conforming to the shift lever over time and that's why used/broken fingers are measuring .311-.318. I would prefer to go on the thicker side, say .325, since the flat area is weak and this is where these fingers consistently break. This may require the lever engagement to be file fitted if necessary but I would rather sacrifice lever thickness for finger thickness.
Who's sick of this?
ID:	24853   Click image for larger version
'65 Mustang SS/L & L/SA
Old 07-26-2014, 12:02 PM   #4
Run to Rund
0.312" is "standard" 5/16" and mine show no signs of wear that I could see with the shifter lever removed. I am probably easier on the trans than most, and have used it less since 2007 than many racers in 1/2 season. The slot in the shifter lever also measured .312" minimum, with a little variation of course because the slot was punched by Hurst/Mr. Gasket.
Old 07-26-2014, 12:39 PM   #5
ROY
I will gladly file fit the arm for a better,stronger finger!!! ROY.
ROY is offline   Reply With Quote
Old 07-28-2014, 12:41 PM   #6
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
I've never broken one nor has any of the people I usually race with around here but will but one just in case if you're doing a run of them. Sounds like a problem waiting to happen.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 07-28-2014, 10:41 PM   #7
ss wannabee
Liked 7 Times in 7 Posts
Did anyone tell Scott to look at this thread? I'm sure with a reputation at stake, he'd
look into the problem.
Great job Bobby....on the r&d to fix the problem!
ss wannabee is offline   Reply With Quote
