Old 07-28-2014, 02:39 PM   #1
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Default Stock Rear end width?
What's the tolerance here? 1/8' , 1/2", 1" , rules say.... distance between backing plates cannot be changed.
I have looked under a lot of cars the last year or so and, well I will just leave it at that.
The question is....I am supposed to measure in at 56" and I have a housing here that's 55", what would you do?
Bill Diehl is offline   Reply With Quote
Old 07-28-2014, 03:58 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Stock Rear end width?
As you said, the rules state that the distance between the backing plates can't be changed from stock (assuming we're talking a stocker). Later it states that a replacement rear end can be widened or narrowed to obtain that original distance. You can't bolt something on to do that so it's would be a machine shop task.
As for looking under other peoples cars, you need to make your own decisions as to whether to follow the rules or not.
Dale
Dale Shearon
68 Mustang 6394
Old 07-28-2014, 05:17 PM   #3
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Bill… Now that 4 wheel disc brakes are allowed, the BP-BP measurements seem to have fallen away. Most fit the tire to the wheel housing and choose rim offset to work. This allows a lower closer to "Stock" ride height. Read deep into the rule (real deep). MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 07-28-2014, 05:39 PM   #4
Pretty much sums up tech's attitude with this.
What can be gained? Loss of a few pounds?
8-10 " wheels only come with few offset options.
Special made wheels with a bunch of offset would be really noticeable on ,say a 69 Camaro, wouldn't they be?
