Old 07-29-2014, 09:44 AM   #1
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
Default Re: Back to back comparison of Th350 and Metric 200???
Randall's truck picked up.30 or .35 it had the 4.3 then you would have to ask him about the 350 he took out had done,but I do know the 200 has manual valve body and that is about it.
I say that probaly isn't normal gain
Don't want to jinx him but I know several times Randall has put over 200 passes,only time he has broke is when he broke ring and pinion,bust sprag/planetary Mike Taylor 3601
Old 07-29-2014, 10:01 AM   #2
Dion Hildebrandt
Dion Hildebrandt's Avatar
I may be doing the burnout wrong , but I have had no issues doing it this way
-roll into the box with shifter in 2nd (auto 1-2)
-bring rpms up to 5-5500
-once rpms have been reached let go of the line lock and roll out until tires grab
I run radials and haven't had any traction problems either.
recently I had a modulator come apart but that has been the only issue with this trans.
- I should note that when we had the trans apart, we could have reused all of the frictions and steels. Gears all looked fine, or new like
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
