Liked 1,575 Times in 580 Posts
Unless NHRA is allowing it now, you may not be able to use a coil over shock and spring in Super Stock class.
Don't have it handy right now but suggest you take a look at the rule book. The Olds Cutlass is a RWD car and did not have coil overs as a OEM configuration. For Super Stock class, the front suspension must be of an OEM configuration. Therefore, OEM control arm with an OEM spring configuration and OEM front shock mount. |
