Old 08-10-2014, 02:47 PM   #31
Default Re: 1966 Hemi Coronet Custom Deluxe
Here is the pic I promised. Original owner, standing in front of Maynard Motors New Hampshire in winter of 67 with his buck tied on the trunk. Those scratches along with a few dozen others are still there. Si and Phil can't top this one!
Old 08-11-2014, 04:22 PM   #32
treessavoy
Liked 4 Times in 4 Posts
Originally Posted by Bob Pagano View Post
Jim, because the scoop only came on the alum. front end cars.
Hey Bob, how are you doing?
I know that but they are putting RO scoops on sedans that never came with scoops so why can't I do the same...put a scoop on a car that wasn't manufactured with one? Looks like the same situation to me.
JimR
Jim Rountree
Old 08-11-2014, 09:36 PM   #33
VanPelt
VanPelt's Avatar
At least it wasn't on the hood. I've seen that quite a few times in my yute in NM.
VanPelt is offline   Reply With Quote
Old 06-17-2015, 12:44 PM   #34
Spyphish
Liked 679 Times in 180 Posts
Check out the Great Race website and under the "Cities" tab you will get the route. This 66 Hemi Coronet will attempt to make the trek. Each stop is a car show so if your on the route, come by and say Hi! Will be using the wipers the first few days
Old 06-17-2015, 06:07 PM   #35
DMann0825
looks like the original trunk mat on top of the trunk panel to protect the paint! and aren't those red line [stripe] snow tires?
DMann0825 is offline   Reply With Quote
Old 06-18-2015, 12:55 AM   #36
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
Originally Posted by theman440 View Post
I believe the NHRA recently changed the rules so you can run the RO scoop on the '66 Hemi cars. As long as it is identical to an original (and steel)
I believe the NHRA recently changed the rules and made the 1969 camaro remove them if it didn't come from the factory.
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
Old 06-18-2015, 01:04 AM   #37
Frank Bialas
JimR
Bad enough it's the wrong body style, 1966 nothing MOPAR made from the factory came with a scoop NOTHING!!! Jim does NHRA know this? Didn't they just take scoops off of the camaro that did not come from the factory.
Old 06-18-2015, 01:22 AM   #38
Frank Bialas
Dave your looking at the red stripe sno tires and I'm looking at the deer, you have a PM.
Old 06-18-2015, 04:28 PM   #39
Geerhead55
Liked 5 Times in 5 Posts
Talking Re: 1966 Hemi Coronet Custom Deluxe
Correct, Frank. For moment I was thinking Jere Stahl's '66 Plymouth championship car had a scoop,, but I googled some photos, and they all showed NO hood scoop! Dang! Its tough getting old,, I suffer from CRS syndrome!!
Danny Durham
Old 06-18-2015, 04:54 PM   #40
Paul Ceasrine
Liked 10 Times in 10 Posts
1966 426 'Street Hemi'
.................................................. ............................Shipping Weight
Dodge Coronet {2-Door Sedan} ........................... #3654 lbs.
Dodge Coronet {2-Door Custom Deluxe} ........... #3658 lbs.
Dodge Coronet 'Model 440' ................................. #3676 lbs.
Dodge Coronet 'Model 440' {convertible} .......... #3790 lbs.
Dodge Coronet '500' ............................................ #3758 lbs.
Dodge Coronet '500' {convertible} ..................... #3849 lbs.
Dodge Charger .................................................. ... #3895 lbs.
Plymouth Belvedere {2-Door Sedan} .................. #3640 lbs.
Plymouth Belvedere 'II' ........................................ #3676 lbs.
Plymouth Belvedere 'II' {convertible} ................. #3763 lbs.
Plymouth Satellite ................................................ #3722 lbs.
Plymouth Satellite {convertible} ......................... #3817 lbs.
Plymouth Belvedere 'Station Wagon' ................. #4100 lbs.
Plymouth Belvedere 'II' 'Station Wagon' ............ #4118 lbs.
'No scoops'
* 1966 ........ 'Top Stock' ....... A/S or A/SA ...... {7.00 to 8.69 ~ Weight-to-Horsepower}
