Old 09-12-2014, 02:19 AM   #1
Rory McNeil
Default Re: 302 Ford 2V
Originally Posted by Pat Cook View Post
The 2 barrel HO Mustang also had a dual snorkel air cleaner, I believe it was the same air cleaner that was used on the later model 4 barrel Mustang's.
Similar, but not the same. The 82 2 barrel HO used a smaller air cleaner housing than the 83 thru 85 4 barrel models. Also, the lid of the air cleaner was basically flat on the 4 barrels, while the 2 barrel lid had a tapered dome. Both versions did have 2 snorkels, which were connected via plastic ridged tubing, to a plastic duct under each inner fender , that was directed behind the bumper rebar. I have ran my 85 Mustang with and without the air cleaner and ducting, didn`t seem to make any differance. I think any benefit from the fresh air was offset by the large aluminum air cleaner housing trapping the heat from the intake manifold, and heating up the float bowls.
NHRA 6390 STK
M/S 85 Mustang
