Liked 61 Times in 12 Posts
All the 383 Dodge and Plymouth engines from 1963 to 1967 had an almost flat intake, 550 cfm afb carb, small exhaust valve heads, and a 430 lift cam. The factory rating horse power was to help in the showroom. Paul covered the 426 street wedge. Hats off to Jim Hale and John Shaul who found a way to make these combinations run very well. A lot of R&D. Not a fat wallet.
John Bender 1969 STK |
Liked 56 Times in 29 Posts
I wish NHRA would de-rate the Olds 400 engines. I haven't seen any in NHRA since Sam Murray's car in 2006. There are a number of old combinations that would be good to see out there but they were factory rated for showroom appeal and are too high for today's competition.
Liked 229 Times in 71 Posts
NHRA will not derate combos at will. They rely on statistics. If a combination is run and it meets the criteria to have hp removed and it is requested, it will be removed. Read up on the AHFS at nhraracer.com.
Liked 11,028 Times in 2,266 Posts
^^^^^ What he said!
#5 | |
Liked 282 Times in 103 Posts
Oldsmobile? No can do. |
Liked 15 Times in 7 Posts
with those heads your talking about you also get weight and horspower.....If i read it correctly
Liked 1,443 Times in 302 Posts
I think Edelbrock sells some Oldsmobile heads. Maybe you should write NHRA and see if they would consider allowing them Daryl. It can't be too easy to find good cores anymore. Pretty good case for allowing them. Heck, it is hard enough to find SBC stuff, some of the BOP stuff is getting rare.
James Schaechter 3163 STK |
Liked 24 Times in 14 Posts
In my case a 29 HP penalty and the Edelbrock aluminum head is NHRA approved but NOT LEGAL AS SOLD!!!
Frank Bialas 1570 STK |
