Old 10-04-2014, 09:27 PM   #5
Bill Baer
Default Re: Head and Neck Restraint Systems
Originally Posted by FED 387 View Post
watch out for the neck size !!!! for a door car you will need a 20* restraint its more UPRIGHT--- 30* is for a more laid back sitting style like a dragster/altered --I understand Simpson has bought and now owns/sells 3 different brands of the "hans" supports--you will also have to either modify your existing helmet or purchase a helmet that is already set up to use a Hans---jsut make sure that any Hans you purchase hase a current SFI sticker on it---you will also need to get a helmet sock/skirt if I'm not mistaken could be wrong on that tho better check the rule book for sure!!!! to use a Hans instead of a neck collar--FED 387
Yep and the lay back is more expensive but the upright fiberglass one is the least expensive the SFI stickers now have an expiration date, helmet mods are simple, helmet skirt is a pain in the butt when fastening the helmet strap (May switch to a balaclava / head sock).
I would suggest the sliding teather option for super class racing.( you still can see better with a neck collar, but they are not as safe/effective.)
