Old 10-14-2014, 06:20 PM   #1
Sam Ehret
Sam Ehret's Avatar
Default best way to know when clutch locks up
I have been running a four speed with a 7.25 diameter,two disk clutch. It has base pressure adjustment and counterweight adjustment. I have an O2 alert data recorder that has a driveshaft sensor mounted on the differantial yoke.
I have been downloading my runs and overlay the rpm and driveshaft readings. The tach goes to 7700 rpm when I drop the clutch, and drops to 5500 before it starts going back up. This is always 1.25 seconds. The driveshaft readings seem to gradually go up with little spin. At what point is the clutch locking up? How do you determine that point? Application is Muncie M20 with 5.38 gears, 3300 lb car. 327 engine.
Sam Ehret is offline   Reply With Quote
Old 10-14-2014, 07:22 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: best way to know when clutch locks up
Multiply the driveshaft rpm by the transmission gear ratio, when that number matches the engine rpm, the clutch is locked up.
ss3011 is online now   Reply With Quote
Old 10-14-2014, 10:33 PM   #3
Chris Hill
Liked 244 Times in 26 Posts
Another way is to take engine rpm/driveshaft rpm.
When clutch is locked up, the ratio will be constant vs time in a specific gear.
Chris Hill
