#11 |
Liked 33 Times in 16 Posts
What size slick you running Chris? Got a side pic of the car?
Rich Taylor I/SA - 321 |
#12 | |
Liked 251 Times in 125 Posts
I'll bet no one ever moved their wheelbase around... |
#13 |
Liked 372 Times in 130 Posts
Here is a copy-n-paste from the 2014 NHRA rulebook:
SUSPENSION, Rear Must remain as produced, except for the following: Leaves may be points at rear end must be retained. See General Regulations 3:4.changed (added or subtracted) as long as overall length and mounting points are used. Coils may be changed (clamped or spaced) as long as stock mounting points are maintained. Solid bushings in rear suspension permitted. Cars with rear coil springs may relocate the upper control arm at rear-end attachment point. Rear trailing arms may be replaced with NHRA-accepted OEM-type aftermarket units. Aftermarket lower unit must be non-adjustable and have bushed ends (no heims). Aftermarket upper unit may be adjustable and use heim ends instead of bushings. Sway bar(s) optional. OEM or aftermarket torque arm permitted only on vehicles OEM-equipped with a torque arm. OEM torque-arm attachment As Charlie stated above, if a racer showed up with lowers that have an adjustable spring height , a tech guy might take it all wrong and ...
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#14 |
My guess is then any lower control arm with solid bushings will do...the cheaper the better. On the hunt for the cheaper now...
#15 |
Liked 227 Times in 74 Posts
Here is my take on this subject. For rear suspension double adjustable uppers everybody makes them, both upper and lower needs to have spherical in all joints, this will make your rear suspension very free when this happens you will need to do some thing like a sway bar or others use air bags to help this. Finding lower arms with spherical bearing in both ends is rare I think BMR makes some.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
#16 | |
#17 | |
#18 | |
Those arms are not adjustable.
#19 | |
#20 |
Liked 5,135 Times in 1,958 Posts
A couple of rings of soft rubber on the outside and ..ah never mind...I didn't say it.
