Old 11-01-2014, 11:57 AM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Stocker Cylinder Heads....
Bill, I have been told that as long as it swings around the guide C/L it will pass.
There seems to be no depth numbers any more. Let me qualify the above statement with "AS OF" July 2014. Rules can be a moving target you better call someone with a little more authority than this message board.
Adger Smith (Former SS)
Old 11-01-2014, 01:52 PM   #2
jmantle
Liked 172 Times in 81 Posts
This is my understanding of the rule. As there is nothing in the rulebook saying you can't cut the manifold face in stock, if the bottom cut takes you over the maximum cc's, it's not hard to fix. I had suggested NHRA add something in the rulebook about not cutting the manifold faces but was shot down on that one. It would be interesting to know how many of the "expensive" heads have had the faces cut.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 11-01-2014, 02:00 PM   #3
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
can't cut past the valve cover bolt holes the way I read it
Bill Diehl is offline   Reply With Quote
Old 11-01-2014, 02:46 PM   #4
Adger Smith
Bill, if it has had any angle milling at all the face needs to be milled to get the angle corrected. Even flat milling the head the intake surface needs milling for the intake to fit in the valley. I would say the odds are pretty good that there are very few that haven't had the intake surface milled.
Old 11-01-2014, 04:42 PM   #5
Lou Jeffery
The basics of Fast stocker cylinder heads are very simple. If you consider each intake port and exhaust port assembly as a orifice you can flow them with a constant draw and establish an effective orifice size. There are endless ways to change or improve flow. The only way to significantly improve flow is to change the effective orifice size of the assembly by porting!
Stop lying to yourselves and Stop pushing NHRA to police something that is out of control. If NHRA were to throw out ALL modified stocker heads the pits would be empty. I know I know it's only the other guys that would stoop to cheating NOT YOU!
Just buy the $1000 cast iron intake and the $3500 heads and have fun like MANY others do. Louis Jeffery
Lou Jeffery is offline   Reply With Quote
Old 11-01-2014, 11:52 PM   #6
dennis dunlap
All this just reminds me of the letter I got from nhra several years ago after being pitched out.... after further review ect ect... what's right?????? Sounds like my x_ wife...... I'm done thanks
dennis dunlap is offline   Reply With Quote
Old 11-02-2014, 10:26 PM   #7
brent flynn
brent flynn's Avatar
Not true, Louis, my slow E/Stocker would still be there, watching tumbleweeds blow across the staging lanes, as i take a final bye run pass, and pull up to the Winner's Circle to accept my Wally... hehe
Old 11-03-2014, 01:02 PM   #8
James L Miller
Liked 25 Times in 16 Posts
I'm looking at building a "killer?" 318 2bbl combo with the 302 swirl port heads. It sounds like I can use a bowl hog and go all the way down to the valve guides as part of the valve job? Or maybe use a Serdi type cutter with a radius at the bottom of the cutter to open up the bowl as long as it's done all the way around?
When did they get rid of the .250" depth cut limitations? I guess I haven't been paying attention to the rules.
I also saw the 308 360 head was legal but needs to have the smaller 318 valves put into it. I guess with the VJ changes that opens up another possibility with new seats and whatever VJ works. It may not make much difference with the tiny BBD 2bbl carb?
Mopar 2 Ya!
Old 11-03-2014, 01:15 PM   #9
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
You would have me there to race Brent.
Rich Taylor
I/SA - 321
