Old 11-03-2014, 11:45 PM   #1
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Ring and Pinion Coating
Derek,
I try to keep records, but I can't be 100% sure I didn't miss noting a gear change. The last one I have noted was at the start of the 2010 season. I can't swear that I hadn't changed them since then, but even if I did, I'm sure it wasn't more than once. I easily do over 100 runs per season and I have gone at least 2-3 seasons without a problem. Last set was changed due to wear rather than cracks. I need to check the current set before next season. Most runs are 1/8 mile, IHRA allows the Mopar aluminum centers and I run Amsoil synthetic lube. Car weighs 3,530+ or 3,700+, 1.47 - 1.52 60' times footbraking with a 360. 11.20's to 11.50's. But even with OEM centers and untreated gears, I've gotten at least couple of seasons out of them. Have you tried anyone else for gear set-ups? Your car is probably heavier, which doesn't help. But I honestly can't remember if or when I may have wiped the whole gear. A while back I had a howling rear and found 3 teeth gone and 3-4 chipped and/or cracked. That was before I started getting them treated.
LOCOMOTION Racing
Old 11-04-2014, 07:45 AM   #2
Myron Piatek
Question Re: Ring and Pinion Coating
Here is a thought......despite the pulses being dampened by the torque converter, does a 2-step have enough affect on the drivetrain to shorten ring & pinion life? I would imagine that leaving at a higher rpm than what is possible footbraking could as well.
If I had a choice starting from scratch, I'd probably go with a Dana 60. But I'd treat the gears in it as well. I just accumulated too much 8 3/4" stuff over the years and experimenting with ratios was easy.
LOCOMOTION Racing
Old 11-04-2014, 08:50 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Default Re: Ring and Pinion Coating
Myron,
If you ever get a chance to change to a Dana 60 you would never have to buy another gear. The only issue with the Dana is the limited number of gear ratios that is available now. The last gear in my car was in for 10 - 12 seasons and it looked perfect when I changed ratios. That would be about 1000 - 1200 runs, I use synthetic lube.
Mike Pearson 2485 SS
